Hi Everybody.
Happy New Year.
I’m little new to sketckup.
I can’t figure out why i can’t make my model into a solid ?
I do believe it’s all closed up.
Cabinet Test.skp (394.3 KB)
All the very best
Finn
Hi Everybody.
Happy New Year.
All the very best
Finn
You have tiny overlaps in the corners, an artifact of using follow me around a curve that is smaller than the radius of the arc.
And a reversed face’
You can see here I delete the flaps and heal the faces with an edge. This doesn’t always work, usually better to adjust your arcs.
Thanks Box.
It’s now working for me.
All the Best
Finn
You should check @Box’s answer as the solution, for others to find, not your post.
All the best for 2025 !
Have you tried the Solid Inspector extension?
It finds and fixes most errors. Sometimes Solid Inspector 2 won’t fix everything , then use 1 to show you where the errors are. Very useful
They are both good extension and I would also recommend them, but neither will fix this particular error.
I found the error from experience, just looking at the shape told me there was most likely an issue in the corners, turning on hidden geometry showed me it was there.
