I can’t figure out what’s up with the image export dialog. I usually export pretty big images with the line scale turned to 0.5 so they don’t dominate the picture. I’m able to highlight the numbers in the Line scale multiplier but it’s stuck on 1.50.
I was able to export the images I needed by opening the model in Sketchup 2024, but am unable to change the scale. Tried both graphics engines, exporting png vs jpeg, nothing lets me do this simple tweak! Any tips are appreciated.
Remember that this option was made to optimize what you’ll get. Unchecking it can lead to very wrong exports. See it as an advanced export option where you can adjust line width depending on a rendering style you want to end up with. You may have to go through a few tries before ending up with the right result. A higher resolution will need a higher multiplier for the lines to be visible and vice versa
