Cannot extrude side wall in Sketchup
Hi. I am new to Sketchup. I tried creating a small house and was able to extrude front and back walls of the house. But when I am trying to build the side wall and window in it, none of the two are extruding with push-pull tool. What could be the reason? Please guide
h1.skp (342.8 KB)
You’ve not been drawing on axis. Note the Y-coordinates in the four blue labels. They should all be the same but they aren’t. You’ve got the same basic problem throughout.
At this point it would be easiest to start over and watch to see that you are drawing on axis. I would suggest turning off Length Snapping in Window>Model Info>Units, too.
It would also be a good idea to go through the Fundamentals here.
Did exactly as you said and it worked. Thank you so much :slightly_smiling_face:
