I am unable to convert a .skp file to into Autodesk Inventor. Can anyone help?
Why can’t you? What file format are you using for export from SketchUp?
I have exported an .skp file as a .dwg file, which is compatible with Autodesk Inventor. However, I was not able to open this file in Inventor. The program locks up. Has anyone encountered this problem?
2D or 3D export?
I have never met a DWG export from SketchUp that wouldn’t open in AutoCad or DWG TrueView, without other error messages than the obvious “this file was created by a non-Autodesk application”.
