Can not see my models anymore I have erased all scenes
hello.
I don’t know what to do, I’ve been working for couples of hour, and I can’t see anymore my model
everything seem to be ok in the structures where every components are in place, but I can’t reveal. please help.
I’m on skp 2024 and on a Mac Ventura
bibliotheque 2.skp (659.2 KB)
There is something wrong with the camera, I copied the geometry into a new model space.
Shift+z, zoom extents, will show you the model, but it will bugsplat if you try to work with it, and fix error tells you there is an unfixable camera issue.
BiblioBox.skp (501.3 KB)
You can also try this with your model.
Shift+z, then Camera/Perspective, then Camera/Field of View, type 36 and hit return.
You should then be able to orbit and zoom out to see your model. But it doesn’t fix the camera issue that may become a problem again.
Does this help?
Biblio.skp (611.6 KB)
(Edit: Uploaded wrong file initially)
seems that shift Z and an other action with the plugin I used seemed to have fixed my problem.
Thanks a lot
