I’ve written a plugin to create mesh-based quarter-elliptical shapes.
Some of the meshes are planar, but won’t push-pull - “can’t push-pull face with softened edges” or similar error message. If I unsoften the edges, I can only select a single facet to push-pull. There are hundreds of facets, so I can’t do them manually.
Will Fredo’s Joint-Push-pull tool work on mesh-generated faces, whether planar, or rounded elliptical faces?
Or is there another way to create a single face in Ruby when it is planar? Just draw the edges, perhaps, then create face?
