________ . reduced to;
Yes. Move end.
Or select it, R-click Entity Info (if you don’t keep it open always, which I would recommend) then type a new length in the Entity Info box.
It’s ‘stuck’ to a Circ,le
You should have indicated that in your first post.
Move the circle, too.
Thank you! it’s 'stuck.
a LINE in SU can never be shortened, it’s infinitely long…
supply an image or skp showing an Edge that you wish to shorten…
if you want a stipple as shown in your first post, that is a different issue that you need to clarify, with words…
both may be possible…
john
Not quite sure what you mean here by 'stuck
That the result has worked and stayed as you want it?
Or something else - perhaps, that the Entity Info box won’t accept input?
Try selecting the circle and making it a group. You should then be able to shorten the line. It should still be attached after you do that.
