# Building/intersecting layers/components without losing geometry
**URL:** <https://forums.sketchup.com/t/building-intersecting-layers-components-without-losing-geometry/51900>\
**Category:** SketchUp\
**Tags:** components\
**Created:** [September 20, 2017, 9:11am UTC](https://forums.sketchup.com/t/building-intersecting-layers-components-without-losing-geometry/51900 "2017-09-20T09:11:15Z")\
**Showing post:** 10
**Author:** ![spawn](https://sea2.discourse-cdn.com/sketchup/user_avatar/forums.sketchup.com/spawn/32/37792_2.png) [@spawn](https://forums.sketchup.com/u/spawn)\
**Post date:** [September 24, 2017, 11:54am UTC](https://forums.sketchup.com/t/building-intersecting-layers-components-without-losing-geometry/51900/10 "2017-09-24T11:54:06Z")
@russell.neilsen thanks for sharing your model I think it’s a good way others like me can learn.
I see you make almost everything as a component, that’s good (better than I do).
I’m nobody to talk about what is right and what is wrong, I tell what I’d like people to tell me.
If you change the color for back faces in **Styles \> Edit \> Face settings** you will notice some of them are reverse. You can all of them and then right clic **reverse face** , I think you can also automaticaly fix it with the extension [Solid Inspector²](https://forums.sketchup.com/t/solid-inspector/5117)
 ![image](https://global.discourse-cdn.com/sketchup/original/3X/a/5/a5e78e9caddc8c88d064b894da0beda361b5e7e7.png)
Once it’s finished you can place it at the origin, you can cut the whole model and paste it like this.
![question](https://global.discourse-cdn.com/sketchup/original/3X/1/e/1ee0e7a29c6770c5b80e70b11837f9398dd89269.gif)
Thank you again 😉
_[View the full topic](https://forums.sketchup.com/t/building-intersecting-layers-components-without-losing-geometry/51900)._
