hi
I have to build a flashing for my model, here I put the photo.
I’ve done a first draft but do not know how to proceed with sketchup to build the wall
I did the skeleton, but now as a continuous …
Thanks
Nicola
lamp.skp (647.5 KB)
hi
Thanks
Nicola
lamp.skp (647.5 KB)
Did you try to use an animated GIF as a texture ?
I built a model for printing 3d, now I have to put on and then build the flashing for printing 3d.
I have to build the housing as it was full.
I’m afraid your English is limited.
You have made the ‘profiles’ [you say ‘skeletons’] of the mesh’s surface.
But now you need to convert them into a ‘mesh surface’.
Fist you need to build the mesh…
You could do this manually, but to avoid a brain-meltdown…
Look on SketchUp Plugins | PluginStore | SketchUcation for Fredo’s ‘CurviLoft’ - or my own ‘Extrude Tools’…
When you have your mesh[es], then you need to apply some ‘thickness’…
Again look there for Fredo’s ‘Joint Push Pull’ tool to do that for you…
