Bugsplat when loading a dynamic component
Hi all,
Have created some dynamic components, these work as expected in the .skp file I created them in.
Now I’m trying to load them into another project file: I can see them in the components toolbar window but when I place them in my model, Sketchup immediately crashes/closes (Bugsplat).
Anyone has similar issues, or has a tips or tricks to get rid of this issues? Response will be highly appreciated.
Thanks,
LucDS
Does the splat happen after more than one of DCs inserted? if so maybe conflict in definition. Solution is to use “deep make unique” after a copy to make component unique and replace the definition.
Can you upload the DCs? Then can confirm this or figure another solution.
Thanks for your response - it happens when I try to insert a single DC.
LDS_DynComp_Kast_Walnut_KiesLeggers.skp (1.3 MB)
I did a deep make unique, so try to insert
LDS_DynComp_Kast_Walnut_KiesLeggers.skp (1.5 MB)
Seems it is no longer a dynamic component, was that intentional?
I’m looking for a way to keep it dynamic, load it in my model, adjust its properties and then save it as a regular component.
Thx
It’s a dynamic component for me when I import it into a SketchUp model.
dc
Thanks Philip, tried it again and works properly as a dynamic component now.
Would you mind explaining what you changed to this component, so I can replicate your solution in the future?
Thank you
I guess he used this:
Eneroth Deep Make Unique | SketchUp Extension Warehouse
…or similar extension.
When reusing a DC to create another it is best to copy it then make the copy unique at every level, Eneroth’s extension does this in one step (including groups) in one click from the context menu.
Another one of her extension is the attribute editor, can excess hidden attributes and copy lists for drop downs
Thanks Philip, most helpful - appreciate the efforts to help fix my issue.
Best regards,
Luc
