I try to delete scenes in an existing file (upgraded from 2025) and I get a bugsplat every time. Either by batch deleting scenes or one at a time.
Can you show a small example file, where you will get a crash if you delete any scene?
I just ran a repair as administrator and that did not fix the problem.
FWIW, I tested with your file and was able to delete all three scenes with no issue.
Do you get the same behavior with this file?
SceneDeleteTest.skp (22.1 KB)
Where has your file been saved when you delete the scenes and get the crash?
Same behavior. The one I uploaded was on our shared server, this one I saved on my hard drive. Same issue.
I think I might try a full re-install.
Same as Dave for me. I could delete any scene with any technique, and not get a crash.
Thanks for testing guys.
YAY!!!
Full re-install seems to have fixed it. Whew.
Did you use the right click, Run as administrator method?
Yep I did
Good deal.
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
