Bug: Rotate+
With the latest update Rotate+ on Just Draw mode doesn’t let you drag/rotate an object around a point. Instead, it now stops abruptly while trying to rotate or uses the first spot you tap.
iPad Pro (11 inch)(3rd generation) 128gb
Model # MHQR3LL/A
Thanks for reporting this one too Roger.
I have it added to the list. Will work on getting a fix out asap!
Thanks Mike!
