please i need help for sketchup make 2017 when i want to duplicate a cube ,duplicate elements are not interdependent and in the copy element the red crosses are absent
Share your SketchUp model so we can see what you are working with.
You will need to explain better what you are talking about.
Except for instances of a component, there is no sharing of anything between copies. Are the things you want to copy component instances? For components you create a copy by activating a copy option on one of the tools such as move or by dragging a new instance from the components window onto the model view.
As to the red crosses, without seeing a sample model I don’t know what you are referring to.
You likely forgot to make the cube a component BEFORE making a copy.
well then you likely forgot to even group the cube before making the copy ? so it’s only raw geometry you copied?
Or did you copy a group then enter the group - therefore no rotation red points ?
I’ll second that. sharing is caring
