Good morning, can anyone help me to better the bottom of the skewer handle? When rendered it has no reflections
ESPETO GRELHA.skp (934.6 KB)
How did you render it? With what software?
This is a V-ray rendering, after applying materials and adding a Domelight.
You will need to orient the faces on the grid correctly (white outward).
Looks fine to me. To have the reflection extend to the end of the handle, you need a longer counter. Or maybe rotate it a bit CW to get what you think it should be.
I’m using Keyshot
Because it’s an image for E-commerce, I don’t need it to be of high quality. but I needed the reflection. See the image below
Put something behind the camera that will reflect in the end of the handle.
