Boolean delete/choose primitives
hi,
pls help,
to keep it simple: having two boxes and a Choice Parameter (right box,left box, both boxes) how to setup the nodes to show boxes following the options at the Choice Parameter (so either right box or left box or both boxes)?
thank you
Hi!
I’m not sure exactly what you’re after without some visual reference, but the best way would be to have each 3D Boolean done seperately, and have the results feed into a switch node which is controlled by the choice node.
Here’s an example: Trimble Creator
Hi, thank you
my question is about visibility of the two objects/boxes, i need to have an option to make right box visible only, left box visible only, or both boxes visible. Maybe Boolean switch is not the right setup in this case… don’t know…
Ahhh right, I see, sorry - when you said boolean I thought you meant a 3D Boolean!
You can do what your after with a similar set up, just merge the two boxes for the “both” option using a collect node.
For the Switch node, just be sure you’re plugging the connections in the right order!
thank you
that is exactly it
easy if you do know how, impossible if you don’t…:wink:
