Ok now I figured something out. Something must be wrong in my configurations somewhere.
I can open up sketch up and use the “Interior production design template inch”.
Than I will draw a square 10" by 10 " piece. Now I will mark it and go to “file” export to dxf in inches.
Than when reopening sketch up in the same inch template I designed it in, than import the dxf file I just created, it will show me a 120"x120" square instead as if i had it drawn in 10’x10’ however I exported it as a 10"x10" in an inch template…
But if I draw it up in inches, in the inch or mm template, than dxf export in mm instead, now when openning the mm template and importing it, it will be all proper dimensions!!!
summerize : inch template/Inch exoport → inch template/import
10"x10" 120"x120" wrong
inch template/mm export -> inch template/import
10"x10" 3048"x3048" wrong
inch template/mm export -> mm template/import
10"x10" 254mmx254mm correct
mm template/mm export -> mm template/import
254mmx254mm 254mmx254mm correct
can someone explain this?
