Hi everyone, I’m new to the forum. I have a broken plastic knob from an old appliance and I’d like to model a replacement to 3D print. I only have photos of the original from a few angles (and the broken piece itself).
What’s the best workflow for getting a physical object like that into SketchUp? Would you use Match Photo and model it by hand, or is it better to generate a mesh from the photos somewhere else and import it as a reference? I’d also appreciate tips on making sure the result is a solid that slices cleanly.
Your profile indicates you are using the free web version. Since you have the original knob, I would suggest taking dimensions from it and model it from scratch. No point in importing images in this case. Measuring from the real knob will allow you more precise modeling of the object with less screwing around.
No. I wouldn’t. And with the web based version you don’t have Match Photo at your disposal anyway.
I leave the model at that size when exporting the .stl file. Then it gets imported into the slicer as millimeters. No scaling required and this helps to avoid issues with tiny faces not filling which would prevent the model from being printable.
for the solid check, i’d make the knob’s geometry a group, select it and look for “solid group” in entity info. if it only says “group”, check for missing faces, stray edges or internal faces; nested groups can also prevent that label. even once it’s solid, check the dimensions and layer preview in your slicer before printing.
Check reality scan app if you want a good free photogrammetry app, it also has a free desktop version where you can download your photos and convert them into point cloud or meshes, there are also paid apps that deliver better results like 3D scanner App, if your phone has LiDar it will get you almost perfect meshes.
