Has anyone experienced the below error message after installing Door? I deleted the door installed originally but the “frame” still shows up on the FACE of the floor plan. No matter how many times I delete the frame it comes right back.
“Can not insert back component. Back wall face was not found.”
Do you have an extension installed for components to cut an opening through both sides of a wall? That sounds like a message from such an extension.
Yes I have ValiArchitects. Should I reach out to them ?
I’m having this same issue with the Vali plugins. Did you happen to reach out to Chuck Valli? Wondering if there is a fix for this. Thanks!
My work-around at the moment is to exploed a component and then reform it. It’s a pain, but it works.
