Autosave's intermittently...possible memory issue?
Continuing the discussion from Files not saving in SketchUp for Web:
hi, has it happened without error message? I have it on Auto save, and appeared to have been working fine. Before I wrapped up work it indicated “Saving”. When I reopened today quite a bit had not been saved…
It should have finished and stating ‘saved’ before closing everything up.
If you go to connect.trimble.com you can check the last save overthere via the details (select the file on the left, open the details panel.
Thanks for the quick response. I must have been mistaken. I could swear it was Saving and I waited to see “Saved” before closing out. Wouldn’t there be an error message if I tried to interrupt the Save? I’m positive that did not occur…so I just have to assume I made an error, since the autosave appears to be working fine. I’m new to SU on the web, and although I’ve used it on my desktop for quite a long time there are enough operational differences with a “learning curve”-for me anyway! I do still prefer it native and I guess I should spend more time exploring the app (thanks for the reminder on the revision history).
