Hello, I would like to know how I can quickly create rooms automatically (as in Revit). The rooms must then be defined by generating a report. It should also be possible to label a room in Layout.
Currently, I do it this way: I create a plane, enlarge it slightly, intersect it with the model, clean up the lines, create it as a component, and create dynamic attributes (name, area calculation).
This method tires me out and forces me to take unnecessary steps, so I need an extension, Ruby code or etc. Please help!
You could just make a Dynamic Component (DC), then insert and scale it to size with the scale tool, instead of creating the component from scratch each time. If you can share your model perhaps I can help you figure that part out. Not sure how many folk are familiar with Revit around here, maybe try explaining what you want without saying ‘like Revit’.
Here is a very basic DC that you can scale to fit the room. Change the name and the Area will show in generate report. I don’t use Layout so I am not sure how/if the Name attribute can be used as a label/room name in Layout…
For example, I can enclose a space with walls and place a “Room” component inside, which would immediately draw the outline of the room around the walls and have the necessary attributes.
Don’t forget to make it unique first! I did not in the video lol. Dynamic Components and SketchUp take some getting used to, it’s a different think than most CAD programs. Perhaps Philip @pcmoor has a better method, he may know how to use the attributes in Layout as well…
