Hi all,
I just make a script to automatic generate the dimension for facade setting out as clip.
Hope you can see and give your thoughts if any.
Thank you so much.
Hi all,
Thank you so much.
It’s not bad from what I see.
Well, the video doesn’t tell me much about how to use it and why is it the way it is? What conditions does the model have to meet? How do you choose what to dimension… etc, etc…
Are you sharing the script (does it meet the requirements of “extension” /“plugin” ) or are you just curious if we’re interested or like it?
Based on my current project, I just create a script to generate dimension to save the time only. I just share the result and see if you have any thoughts or any idea about that.
Currently, I just select the 3D model group then run script to generate the dimension. I just try to automation all repeated and boring works.
Thank you so much for your comment.
