The auto-text window in layout 2026 is empty. I work with the program in brazilian portuguese. The auto text optins that appear when I use the insert auto-text option are now in english. They used to be in portuguese. I would like to know if there is something wrong from my side or if this is some bug.
so, there is a bug, I spotted it on a french version / PC.
(@adam it’s also under ISS-2278)
if you select downward (grid, then groups, paper…) then about half of the panels are broken.
but if you select from the bottom up, they work ok.
can you try this like in the video and tell me if it works ?
I didn’t know if it was french only, looks like it’s also portguese.
Surprisingly it worked! Thank you very much!
ok, that’s great. as far as bug goes ![]()
because it’s a bug that you can step over for the time being
let’s hope for a quick identification and fix ![]()
We have identified the issue here, which occurred with our migration to the Qt UI on Windows. The issue is limited to translated installations. Our next release should contain a fix for this.
Sorry for the inconvenience,
Adam
