As my School's G Suite for Education IT Administrator, how do I deploy SketchUp for Schools?
Okay, you’re on the whitelist now. @ckirch
Can you please whitelist @maranausd.org? Will this cover sub-domains? If not please add the following:
@g.maranausd.org
@stu.maranausd.org
@abusby I put all three domains on our whitelist just to be safe. It should work now.
Hello, Would you be able to white list our K12 domain? www.cr.k12.de.us We use Schoology as our primary LMS and do not want to turn on Google Classroom. Thank you for your help! Carolyn Bush - Caesar Rodney School District
@Carolyn.BUsh your school is on the whitelist now.
Can you please our K-8 domain “www.pesd92.org” for Sketchup for Schools?
Hello,
Can you please whitelist following domains as well?
edu.stockholm.se and elevmail.stockholm.se.
Thanks!
Hi @renat @Abijah21 your domains are on our whitelist now.
Joy Can you please whitelist mevsd.us.
We have been getting the “Are you sure your in the right place?” page when kids login to use it.
Can you please whitelist @atlascollege.nl for Sketchup for Schools.
Kind regards,
Frank
@billy.ruhlen @frankkohne353 your domains are whitelisted.
We are experiencing the same “are you in the right place” errors and cannot login. Can you add us to the whitelist as well?
@proctor.k12.mn.us
Thanks!
@sfitzsim added.
Thanks for the quick action and replay guys!
My district is seeing the same “are you in the right place” errors and cannot login. Can you please whitelist naperville203.org and stu.naperville203.org?
Hello,
I have the same issue, Sketchup for School installed on my G Suite for Education, all Classroom/data access ok.
Do you need to whitelist my domains : lilaschool.com and lilalions.com ?
Thanks for your help
Can you please whitelist @iessaserra.cat so we can use it? Thank you very much!
@wizstef @jcardona all set.
Thank you for that, but I still have the same issue, do you have any clue
SIGN-IN ERROR
It looks like you’re having trouble signing in. Make sure you’ve enabled pop-up windows for SketchUp, then complete sign in using the pop-up window that appears.
Please note: SketchUp for Schools is only available for students and teachers in primary and secondary education programs
When I try to add SketchUp for Schools to our domain in the google admin console I get a “We are unable to process your request at this time. Please try again later.” error.
Will the whitelist fix the issue or is there something else that needs to be done?
Our domain is mcintosh.k12.ga.us
Thanks!
