In SketchUp, a dimension will update automatically if the edge is resized.
But an Area Label will not update if a face is resized.
Should it not be the same as a dimension?
Also, when an area label is added, and the face is resized, the area label commonly flies off into a different place…it’s not attached properly. This can cause zoom scale issues and clipping (and other issues). I would like to see the area label attached properly (even if it’s put into a different layer to the face).
I am using the area by material property in a component that I use as a space object for a room finish schedule. And when I change the size of the face it doesn’t update until I force it by hitting redraw. I think it’s buggy.
