Arange Objects Layout 2025 Not Working
Anyone else having issues with the arange function? Send to back, bring to front, none of that seems to be working in 2025 for me.
The typical reason for a report like this is that the entities are on different layers within LayOut. The Arrange functions only work on entities that are on the same layer. This is in LO2025. The rectangle and the viewport are on the same layer.
arrange
Share the LO file so we can see your setup.
To add to what Dave said - arrange only works to move objects behind / in front of another within the same layer, and layers work as if you had sheets of trace paper stacked on top of one another.
You can see what layer and object is on by selecting it and looking at the layers panel - you will see a little box (red or blue) for the layer it is assigned to.
Thanks! I’ll give that a try! I usually don’t use layers too much in Layout, but I was coping and pasting things in from old drawings so that might be it.
You probably should be using layers in LayOut. It would add a lot of control to your LO projects.
I expect it is.
