test.rb (354 Bytes)
if you create a component and select it, then run the ruby code multiple times (5-10 times at least to be sure) the result of the text.leader_type parameter will be 1 or 2 , although the code sets that parameter to 1
test.rb (354 Bytes)
I do not see this happening on Win10. Perhaps this is only a Mac M1 issue ?
It might be a issue with Console IO [ ie, the puts()
call ] with Ruby running on M1.
module Testing
def self.go
model = Sketchup.active_model
inst = model.selection.first
outer_entities = inst.definition.entities
types = []
model.start_operation("Text Test",true)
10.times do
group = outer_entities.add_group
group.locked = true
inner_entities = group.entities
cpt = inner_entities.add_cpoint(ORIGIN)
text = inner_entities.add_text(
"TestName",
Geom::Point3d.new(30, 30, 30),
Geom::Vector3d.new(0, 0, 35)
text.leader_type = 1
text.arrow_type = 2
text.display_leader = true
puts text.leader_type # slow IO
types << text.leader_type
cpt.erase!
end
model.commit_operation
puts "True leader types: #{types.inspect}"
end # go()
end # module
module Issue792
def self.go(num = 10)
objects = []
num.times do
group.locked = true
"TestName",
text.arrow_type = 2
objects << text
cpt.erase!
end
types = objects.map(&:leader_type)
end # go()
end # module
If you still see the issue, please log a report in the API Issue Tracker:
