Aplo: modelling tools that think in buildings
Hi, I’m Michael. I’ve used Revit for seventeen years, and for a long time I’ve also made and sold Revit window and door families. What I love about SketchUp is the opposite of Revit: you just model, and nothing makes you decide what something is before you draw it.
I want both. I want the tools and intelligence of BIM: walls that join properly, openings that know which wall they sit in, corners that resolve themselves. And I want to keep SketchUp’s generic modelling. Every time something gets a category, a bit of freedom goes. So with every tool I try to find the balance: enough BIM to save work, but never so much that you can’t just model.
So far that means:
  • The tools work on whatever is already in your model: a loose line, a group, or a wall from another extension. Nothing has to be drawn “the Aplo way” first.
  • Each tool should just do the right thing and follow SketchUp’s conventions, with no list of parameters to work through first.
Aplo is evolving all the time. New and improved tools come out regularly, and I post each release as a reply below.
Now: Free Modelling tools, listed at Aplo Modelling — Aplo.
Later: Aplo Architecture, walls, openings, doors, windows and more…
Get it: Download Aplo — Aplo. Needs SketchUp 2024+ on Windows or macOS.
I write about every step, and why I took it, in the journal (Journal — Aplo).
I’d love to hear where you’d draw that line between BIM and freedom, and where modelling in SketchUp slows you down.
Question: How does the tool know if it’s a wall and how to behave when it encounters a T or even corner?
@MikeWayzovski good question. These tools came out of my work on the Aplo Wall, which is still in development. An Aplo Wall is a real wall: it knows its layers, each layer’s function and priority, and where its core is. When two Aplo Walls join, the structure decides the result. Higher-priority layers run through, lower ones stop against them, and nothing runs past the core, the way you’d detail it in Revit.
While modelling our house I realised I wanted Trim/Extend on everything, not only on Aplo Walls. So for anything that isn’t an Aplo Wall, the tools read the geometry instead. A wall from other extensions isn’t really recognised as a wall (not yet at least). It’s read as stacked geometry: a group of solids where each solid is a slab between two parallel vertical faces, all running parallel to each other without overlapping. A single solid is a stack of one.
Because stacked geometry carries no priorities, every layer counts the same, and the join is purely geometric.
If a group doesn’t read as a clean stack, for example layers at an angle or two layers claiming the same space, Aplo leaves it alone and says why in the status bar. It doesn’t make a best guess.
You choose Corner or T by picking the tool, and the side you click on is the side that stays.
Alongside the wall I’m also working on the Aplo Opening, which may be closer to your MEP world. An opening is its own object, not part of a door or window. A hole with nothing in it is a legitimate thing, so is one made for a duct or a pipe. It also works on plain SketchUp geometry, not only on Aplo Walls. Each edge (head, jambs, sill) can carry its own reveal per wall layer, so a penetration through a layered wall can be detailed properly, not just punched through.
You’ve seen SketchUp as a contractor, a designer and a trainer, and now from MEP. Is there a modelling task where you thought “there should be a tool for this”? Or something you always had to teach as a workaround, five steps that should be one? Or a penetration or opening situation that’s painful today? That’s exactly the kind of thing I’d like to work on.
Well, I got along well with Profile Builder, which in a way can categorize multiple Profiles into Assemblies as a layered wall the way Revit does. That extension also has a hole tool to cut openings with those layered walls, btw. The moment you start categorizing, that’s the moment you start loosing a bit of ‘freedom’ …
Aplo 0.4.0: rounded and chamfered corners, in plan and in elevation
Our house will be built on a slope, so this week I needed to model a ramp: landing, ramp, landing, with a transition at each end so a car doesn’t ground on the edge. Up to 0.3.1, Trim/Extend to Corner could only make a sharp corner, and only in plan. 0.4.0 fixes both.
What’s new in Trim/Extend to Corner
  • Radius: type a length before or after the clicks and the corner is rounded. Between two lines it’s a real SketchUp arc, so Entity Info shows its radius and segments. Between two walls or slabs, every layer bends around one shared centre. The curve is a separate group, so both walls stay straight and can still be trimmed and merged.
  • Chamfer: type 300;450 to cut the corner back 300 along the first piece you click and 450 along the second.
  • Elevation: the same two clicks work on two lines in one vertical plane, or on two slabs, where a ramp meets a landing. A narrower ramp, or one off to one side, still works as long as it overlaps the landing.
  • The first piece you click sets the layers of the bend. If the second piece has different layers, it meets the bend with a step.
  • The face you click is where the radius is measured (inside face, outside face, top surface or soffit). Before the second click, Ctrl (Option on a Mac) steps through the faces, and the preview shows where the arc ends up.
  • Click the same pair again to replace a corner you made earlier. A radius of 0 makes it sharp again.
Also new
  • Trim/Extend to T: when you bring one layered group to another, every layer stops on its face.
  • The preview now draws the actual result before you click.
Not yet
  • Trim/Extend to T and Merge still work only in plan.
  • A rounded corner doesn’t move with the walls yet. Move the landing and the arc stays where it was until you round the corner again. That’s what I’m working on next.
Update from inside SketchUp, or download at Download Aplo — Aplo.
v0.5.0 is out, with a new free Modelling tool: Lengthen
This one came from something that kept bothering me. Making a line longer in SketchUp is easy as long as it runs along an axis. As soon as it doesn’t, I lay a Tape Measure guide along it, Move the end along the guide, and delete the guide again. Walls drawn as stacked groups were worse. I could Push/Pull each layer on its own but never the whole group at once, and on a mitred end Push/Pull pushes the way the face points, so the end bends off instead of running on.
Lengthen does it in one step. Click near the end of a line, or on the end face of a group, and type +500, -200 or 1500. The end you clicked near moves along the piece’s own run, at whatever angle it lies, and the other end stays where it was. If you know Revit, it’s the temporary dimension you type into on a selected wall. In AutoCAD it’s LENGTHEN.
lengthen-tour
It works on:
  • Lines, at any angle. At a corner it adds a new piece in line, so the face stays whole.
  • Layered groups like walls: every layer together, and a mitre keeps its angle.
  • Ramps and slabs, along their slope.
  • Loose beams and rafters, along their edges, so a plumb cut stays plumb.
  • The top or bottom of a wall, to change its height. Openings stay where they are.
Journal: Lengthening a line that isn't on an axis — Aplo
Tool details: Lengthen — Aplo
Download: Download Aplo — Aplo.
If you already have Aplo, you can update inside SketchUp.
You can lengthen any edge in its own direction, even when off axis. And by inputting an exact value if desired.
v0.6.0 is out: drag in Lengthen, and gable walls
After v0.5.0, @Wo3Dan pointed out that SketchUp can already lengthen any edge in its own direction, off axis too, and with an exact value. Thanks, I tried it: grab the end with Move, lock it to the line with Shift and type the distance. It works, but I find it fiddly, it only takes a distance and not a total, and it can’t reach into a stacked group. What it does have is the drag, and Lengthen didn’t, so I added it.
lengthen-drag-gable
New in Lengthen:
  • Drag it or type it. After the click the end follows the mouse along its own run, as Move does when it’s locked to a line. The change is drawn dashed and the Length box shows the length it would leave. Click again, or press, drag and let go. Hover an endpoint and the end lines up with it.
  • Gable walls. Click either slope and both rise together, so the gable keeps its pitch and the ridge stays in the middle. Drag an end out and the eaves follow the slope.
  • Double-click to repeat. Double-click the next end, top or bottom and it gets the last change, typed or dragged, as Push/Pull does.
  • Edge-on picks. In a Front or plan view, click the line of an end face or top seen edge-on and Lengthen takes the face behind it.
Journal: There was a native way after all — Aplo
Useful, with good functionality and easy to use. For me, the downside is that it’s only for SU 2024+; it would have been nice if it worked with SU 2022 or earlier versions.
Lengthen 0.6.1
Lengthen now types like Push/Pull. 500 moves the end the way the preview shows, -500 moves it the other way and =1500 sets the total. A bare number used to set the total, and it kept catching me out.
It also works on shapes it used to refuse: walls with an angled leg in one solid group, an L or a U (including its top), and one wall inside a group of walls without opening it.
More in the journal (Typing a length the way Push/Pull does — Aplo), download at Download Aplo — Aplo.
v0.7.0 – Moving things by editing dimensions
I’ve been moving geometry around a lot lately: a cabinet against a wall, a shelf a set distance below the ceiling. Each time it was the same routine. Tape Measure to find the gap, a sum in my head, then Move by the difference. That’s three tools for what is really one thought, “this should be 600 from that wall”. In Revit you click the temporary dimension and type 600, so that’s what the new dimension tools do.
temporary-dimensions
Temporary Dimensions. Select something, then Option-click a face, edge or corner (Alt on Windows) to see how far the selection is from it. Click the label, type a distance, press Enter, and the selection moves there. Nothing stays in the model.
  • Shift-Option-click adds more Targets, so you see several gaps at once
  • Cmd-click (Ctrl on Windows) picks the part of the selection to measure from, starting at its middle, which is handy for centring
  • Arrow keys lock the direction, the same way they do in Move
  • However many values you try, one Undo takes it back
Nearest Dimensions. This one shows the gap to the nearest face on each side of the selection, with no clicking needed. The labels take a typed distance the same way. Hold its shortcut for a quick look: you can be halfway through a Move, hold it, read the gap, let go and carry on moving.
I bind D and Shift+D, and pressing one while you’re in the other switches between them.
My first try was plain hover, like Revit. It kept grabbing the floor while the mouse moved towards the label, so I borrowed the hold-Option-to-point idea from Figma instead. I tested the tools against a model with 117 checks, and the full story is in the journal: Moving things by editing dimensions — Aplo
Also in 0.7.0
  • Works with SketchUp 2027’s model tabs: each tab keeps its own tool state and selection
  • Lengthen is stricter about what counts as touching the end it moves, so a ramp or a run now lengthens past a piece running alongside it
Tool Pages:
Free download, or update from inside SketchUp: Download Aplo — Aplo
If you get a chance of trying these new dimension tools, I’d love to hear about. Does picking with Option-click feel natural? Do you end up in Nearest Dimensions most of the time? And where does it measure something you didn’t expect? A screenshot of the setup helps a lot, because I’m sure there are cases I didn’t test.
