Another wip project: 1970 Porsche 908/03
Awesome! After the last basecamp in 2018, I watched this exact car rip around Laguna Seca at Rennsport Reunion.
Union Jack and different paint shop on the sides of the rear hood added.
Now back to the internal work - adding tubes and pipes…
More details added on the engine: spark plugs, nuts and bolts to fix the cam shaft boxes on the pistons…
Piston redrawed according to new details pics.
Cheers
Torsten
Starting with wires - first wires for the spark plugs build with some guide-lines, BZ-Toolbar for bezier curves and followMe for the final wire geometry.
my workflow to “draw” wires :smiley:
8 wires per cylinder bank - porsche uses 2 sparks per cylinder for a better performance.
I did it also for the exhaust pipes…
What does the BZ-Toolbar provide in this situation beyond what native Follow-Me could produce? I’m just curious; I’m not familiar with BZ-Toolbar.
Its Fredos BezierSpline Plugin - it helps to draw different bezier curves and you can adjust the curves.
Then the FollowMe-Tool make the wire from a circle.
Ahh, I see. Thanks for the explanation. I have used the Bezier extension provided by SketchUp (as I recall it’s origin), which has been useful despite its limited capabilities.
Hi there! just wanted to thank you for sharing the project, is really amazing.
A work of love. Great results!
