Animação em 2 estágios
Good morning
To make a fluid animation of the duration of your choice combining several movements, it is necessary to animate a numerical value which will correspond to the time.
Example, I vary the time value of an “Animation” attribute from 0 to 2000.
  • From 0 to 500: opening left door by -90° rotation Z
  • From 500 to 1000: Retraction by translationof the left door Axis Y
  • From 1000 to 1500: opening of the right door by rotating 90° Z rotation
  • From 1500 to 2000: Retraction by translation of the right door Axis Y.
For each movement attribute, you do a test to know in which stage of the animation you are and if it is the right time for the attribute to animate, you do a rule of 3 to define its value.
Annimation Gif
