Angle Object
Hi all, I’m trying to angle my object. I’ve tried a few methods, but my best attempt seems to distort the object and does not create an even angle. I used the rotation tool along the face but not quite exact and there appears to be a slight twist. Not sure if the rounded corners are the issue? Any suggestions greatly appreciated!
Object.skp (42.1 KB)
What exactly do you mean by angle? Do you want to make it tapered? If so, use Subtract from the Solid Tools to subtract a cutter volume from the object.
Sub
Thanks Dave, that looks exactly what I’m trying to accomplish! Will give it a shot on my end now! :slight_smile:
You’re welcome.
BTW, please put the SketchUp version you are using in your forum profile. That information helps us help you if it’s correct and complete.
