I am trying to align the view with Face A but for some reason when I select Face A then Align View nothing happens, although when I select Face B then Align View everything works as usual.
I am missing something obvious or doing something wrong?
Thanks’ - maybe that has something to do with it?
I created the wall profile from a point cloud and initially welded all the edges together but it looked strange when I extruded it, so I undid the weld. Maybe it still did something strange to the lines?
Look at it closely with the Show Hidden geometry option on. Align view might require a single face to work correctly. Not at SketchUp right now so cannot check.
Because of the hidden geometry enabled in your model you are selecting a face, but if the hidden geometry not enabled you can select surface “only”. For surface the align view will not work, I guess.
I just turned on hidden geometry and saw a vertical line on the problem face line which I deleted. Then everything was fine. Prior to that I had welded the wall profile prior to applying a 100mm offset and extruding it which looked strange (like the wall had been softened) so I undid the weld and the wall looked correct but then I had the align view issue?
