Another morning coffee exercise, I asked Google Gemini to review and rank these 3 sketch plan alternatives for space and circulation efficiency..
Here is its critique
Space and Circulation Efficiency Critique
Based on architectural principles and the provided sketches, the layouts are evaluated as follows:
Option B: Nominated Best Option (Rank 1)
- Multi-functional Circulation: This layout is the most efficient because it transforms the entry hallway into a functional “drop zone” with integrated wardrobes (W/R). Research suggests that hallways should be designed to be multi-functional to minimize wasted square footage.[1]
- Logical Zoning: It separates the “wet core” (bathroom) and the master suite from the main living area, creating a clear and logical path that feels natural to the inhabitant.[2]
- Wasted Space: By consolidating storage and utilizing a wide entry, it achieves a high ratio of usable space (Net Floor Area) to total footprint.[3, 4]
Option A: Moderate Efficiency (Rank 2) - The “Backbone” Layout: This is a traditional approach where a central corridor acts as a “circulation backbone”.[5] While this provides the best acoustic privacy for bedrooms, it is less efficient as the hallway consumes space solely for movement without adding storage or utility.[1, 6]
- Bottlenecks: The placement of the bathroom in the center creates a potential “pinch point” in movement between the two primary rooms.[2]
Option C: Lower Efficiency (Rank 3) - Open Concept Trade-offs: While the open plan maximizes natural light and social flow, it introduces significant circulation flaws.[7]
- Minimum Travel Distance: The shower (SHR) is placed at the far peripheral edge of the “L” shape. This creates the longest possible travel distance from the sleeping area, failing the “minimum travel distance” test for intuitive residential flow.[2]
- Privacy and Noise: Without buffer spaces like hallways or closets, noise and odors from the kitchen and bathroom travel freely through the living space, which can reduce habitability.[8, 7]
Final Rankings Summary
| Rank | Option | Key Rationale |
| 1 | Option B | Best use of space; incorporates storage into circulation. |
| 2 | Option A | Traditional and private, but higher percentage of wasted “dead space”. |
| 3 | Option C | High light access but poor functional zoning and excessive travel distance.[2, 9] |
| For a standard residential unit, aiming for a hallway width of at least 36 to 42 inches (90–107 cm) is recommended to ensure comfortable passage and furniture movement. |
And to understand what it considered here is its json structure…
To ensure you can access the analysis despite any display issues with the previous results, I have provided the full critique and ranking of Options A, B, and C in a structured JSON format below.
"design_critique": {
"nomination": "Option B",
"rankings":",
"Zoning: Clearly defines a private master retreat while maintaining an open, social central hub.[2, 3]",
"Plumbing efficiency: Groups 'wet zones' (bathroom/kitchen core) to minimize mechanical runs and cost.[4, 5]",
"Entry sequence: Provides a psychological 'soft landing' with a dedicated foyer, avoiding direct visual exposure to living areas.[6, 2]"
"est_efficiency_ratio": "82% - 85% (NFA/GFA) [7, 8]"
"rank": 2,
"option": "A",
"title": "Traditional Sequential Layout",
"summary": "A functional but less efficient approach that relies on internal partitions and a central 'backbone' corridor.",
"strengths": [
"Privacy: Offers the highest level of acoustic and visual separation between individual rooms.[9]",
"Traditional Sequential Flow: Follows a familiar residential logic that is easy for residents to navigate intuitively.[10]"
"weaknesses":",
"Bottlenecks: The placement of the central bathroom creates a potential pinch point and lacks proper visual shielding from common areas.[11, 12]"
"est_efficiency_ratio": "75% - 78% (NFA/GFA) [13]"
"rank": 3,
"option": "C",
"title": "Open-Concept Fluidity",
"summary": "While visually expansive, this layout suffers from significant circulation errors and lack of privacy.",
"strengths":",
"Theoretical Efficiency: Highest potential ratio of usable floor area due to the removal of interior walls."
"weaknesses":",
"Lack of Privacy: No entry transition; visitors 'barge' directly into the living space, and there is no acoustic buffer for 'wet' noises."
"est_efficiency_ratio": "88% - 92% (NFA/GFA)"
"design_benchmarks": {
"min_hallway_width": "36 inches (approx. 90 cm) for basic passage; 42 inches (107 cm) recommended.",
"furniture_clearance": "30 to 36 inches (76-92 cm) required for comfortable movement between pieces.",
"circulation_efficiency": "Residential units should target >80% Usable/Net Floor Area (NFA) relative to Gross Floor Area (GFA).[7, 8]"
What option would you have chosen based on those criteria ?
PS, I recently visited my doctor, during the consultation he commented on how many of his patients used AI to get second opinions on his diagnosis.. expect the same from your clients…
Curious to know if any of you have had first hand experience of this ?
