I have the experience that after adjusting axes viewing my model is much more difficult. Rotating and panning do not function in the same way as before the command. Am I doing something wrong or is this the consequence of adjusting axes?
Cheers,
Bert
Be sure to have (=keep) the blue axis pointing up (=original direction).
Otherwise you will experience unexpected orbiting.
p.s. orbiting still uses the systems axes while you may expect it to use your axes.
Select a style with the horizon visible to avoid getting seasick
Changing drawing axes should not in any way alter how the camera tools work. Maybe you have at the same time made the model larger with nested groups/components.
