I can not seem to get Advanced Camera Tools to work correctly, I Was able to get 2 cameras to work, but now every time I try to create a new camera, things start clipping, where they are not supposed to. like the attached image. What am I doing wrong?
No, that did not help… its only when using the Advanced camera tools… Before that I never had a problem… I just tried everythig you said, and none of it worked.
The advanced camera tools can cause clipping depending on how you created the cameras. Can you post a model versus just a picture? That will allow the experts to tell you exactly what is wrong.
Advanced camera tools can create ridiculously large camera angles which means the camera is miles or kilometers from your model. Try Zoom extents, you’ll probably find your model is a tiny speck in the distance, and if you ‘select all’ there will be some strange bounding boxes.
I don’t use ACTs, but every time I have seen this problem deleting ACT scenes, or something along those lines, fixes things.
Box. Thank you. I think that is what Sketch3d_de was trying to tell me… but I wasnt understanding… based on what you said, I did that and you were right…
Thank you so much!
For a beginning like myself, is there another option to trying make more real life perspectives with out using advanced camera tools?
