I was referring to what exactly the skp model you created looks like?
How did you model it? Is it made of pieces? Does it have thickness or is it just the face?
How did you try to apply the texture? How did you position it in relation to the model?
Is the geometry grouped? Did you try to apply the texture to the geometry or to the group?
Try to understand that no one but you has any way of knowing what you did there, so when you ask for help you should provide all the data so that we don’t have to guess what you did.
As you can see in the video, a texture can be applied to a wavy surface.
Understood and thank you for helping. The model is herehttps://app.sketchup.com/share/tc/europe/wRDZbWgwnrE?source=desktop&stoken=lPO5IiLO1hNdOsn2cGpO3rGO0PVBmMEAxob1W39S13gwyKb8c0UG94MHWU5nflLF
You chose to share a link to the viewer, meaning it can only be viewed but no proper edited and analyzed. From what I could see in your model, the geometry is grouped, has thickness, and some edges are hidden, creating a continuous surface on all sides.
When you want to share a model, you download it as an .skp file first and either drag it directly into the window where you write the message, or, if it’s over 16 MB, use a sharing service (Google Drive, Dropbox, etc…).
Ok I think I am missing something here, thanks all for your videos but I have no sound for some reason and so I stuck at the part where you selected the group (corrugate element) and then select the dropper. From there is only picks up the single colour and not the whole image… what am I missing please SketchUp
I edited the group by double clicking, and inside I selected only the necessary face, on which I then applied the texture that I sampled from the image.
If you need tutorials with audio, then follow the basic SketchUp courses on Campus - https://learn.trimble.com
Search the forum or SketchUp help to see what the sample entire image setting is on Mac.
