Hi everyone. I’m working through a sketchup course and when i add a tag to a group via entity info or using the click to tag, the group disappears.
heres a quick video showing what im doing.
many thanks
many thanks
thanks Mihai! Clicking all the tags on an off changes nothing unfortunately. Even changing the folder doesnt work sadly. I still cant see where it goes unless i hit undo. Any ideas?
Attach your model so we can see what you have.
seattle2.skp (7.5 MB)
Tested in SUP2025 but should work the same in SUP2026.
You still had the Geo Location Tag Group turned off (as @mihai.s mentioned) when you turned on that x-sketchplan tag, which is also seated inside that group you turned off ![]()
below you can see i..
hope this guided you to the right direction ![]()
In SU2026 it works as expected, if you follow one of the steps I indicated.
Thank you so so much @mihai.s and @AnnoNiem!!
really appreciate your efforts in helping me out!
super appreciated thank you again!
This topic was automatically closed 7 days after the last reply. New replies are no longer allowed.
