Very often you have to twirl a 3D object for editing and texturing. At the same time, the scene is loaded with other objects that interfere with this. Please add the function - Hide everything except the selected object.
If you select an object (group or component) there will be an option to invert the selection in the right click context menu. Then hide the inverted selection.
If you need to edit inside the object, there is the option: ‘Hide Rest of Model’.
It doesn’t have to be added. View menu>Component edit>Hide rest of model. I have assigned a shortcut to it.
