Hi
There is a way to model Structural detail with any plugins that make possibility to add different direction joints on any lattice structure form?
Hi
Take a look at Profile Builder. I am not sure if it helps with your model but I have seen it used when modelling lattice trusses, for instance.
This may be a solution but I would prefer testing on your model. Also, what are the size specs for the connectors?
So much thank dear sdmitch.
Thanks for the specs. How about a model I can test on.
Thanks. As I suspected, my test model was much to simple. I will need to rethink a few things.
I have sent you a file attached to a message.
Thanks a lot.
Can we see a screenshot of a close up of the result of that plugin, how it performs on your model?
