Absolute Values
Last week SketchUp 15 quit using absolute values when entering dimensions and or lengths. It now shows ~ 1mm instead of .5mm. Is there a setting or preference that can be changed back to how it was? Also, the endpoints are different. Instead of just one, there are multiple around corners.
Thanks for your time.
Window >> Model Info >> Units >> Precision…
john
SketchUp appears to be using a different template. You can open Window → Preferences → Templates and try to find the template again that you previously used.
Alternatively, you can just change the settings in the current template and afterwards you do File → Save as Template:
  • Unit is mm, but amount of decimal places is wrong: change Model Info → Unity → Precission
  • Endpoints are enabled: Open Window → Styles → Edge Style and disable endpoints.
