The save buttons at the bottom of the Default Parameters dialog boxes are cut off by the window.
Expanding the box does not help.
Nothing is cut off here. I see the buttons!
Can’t you grab the bottom edge of the dialog and drag it down to see the buttons ?
It should stay like that between sessions…
It’s ok for me here at a few differing scaling setting : You might want to try clearing the webcache folder
AppData\Roaming\SketchUp\SketchUp 2022\WebCache
The video shows the attempt to do just this.
Just delete everything in there?
No effect.
Yeah, just delete it all inside or the whole folder itself.
Is the libfredo upto date? There was a new version a couple of days ago 13.7b
Are you using multiple screens?
What resolution and scaling setting is each at?
Yes
Yes
Different scaling, same resolution. Not at home RN
When you are back, try dropping them both to 100% scale (to disable scaling) quit SketchUp and try again. I’ll be curious if you can see it after that
Congrats, that was the issue, I had one screen set a custom scale.
They don’t recommend it.
I don’t recommend it either.
Thank you!
