5D+ Plus - Flexible Documentation For Architects
I do not quite understand this, can you take a screenshot?
That’s my mistake. I added supporting for Fractional in annotations text for the next release.
Yes, we can change the edge colors in Edge Settings of a style (change Same Color to Color by Material). But it can be come more complex.
So, in Paper, we have Line Styles for exporting PDF, it can change color of output.
This will be supported in the next release
Here’re you can access the full list of variables for Curic Text
I agree, this also will be improved in the next version 3.2.0.
This also will be supported.
I will added support for changing the color and opacity. But there will be a limit for opacity in Color By Tag mode, since SketchUp doesn’t have an API to change the opacity for tags.
Thank you for taking the time to explore 5D+ and write such thoughtful, detailed feedback. Your kind words mean a lot to me, and your honest criticism is just as valuable. It helps me see where things still get in the way of real work.
Seeing you find value in the workflow I’ve been building is incredibly encouraging. My focus now is on refining that experience—making it smoother, clearer, and easier to use. Please keep sharing what you discover!
doubleclick to edit text - its about 50% of my screen too far to the left when it pops up. Sometimes it pops up off screen.
Also happens with right click context menu.
Huhm, this is weird. You’re the only one report about this issue till now.
Let me think about this issue, how it can be happened.
Don’t wrack your brain too hard. I use a good deal of other plugins and scripts which could be causing this bug.
I have a problem in Layout with the file published from 5D+ Drawings. The file opens in Layout 2026 and 2027 without a problem. However, it can not be saved or saved as.
Is there a known issue regarding this?
Hello, can you send me your file via P.M?
Dropbox link sent.
Hi, I have been using both free and paid 5D+ en Curic extensions for several years now, and am trying to find a way how to combine my current workflow with the latest release for 5D+ Plus.
Potentially using the 5D+ Plus Dimensions, Annotations and Paper features is what i am really excited about, to not having to deal with the disconnect with Layout and constantly synchronising my viewports.
In my current workflow i am using in almost all of my Scenes different custom Styles with ‘Edges color by material’. (such as ‘Edge Material Wireframe’ , or ‘Edge Material White Faces’)This allows me to easily control line colors inside Sketchup by just painting the edge or group, to visually differentiate some elements from al the other black lines, like electrical, hvac, plumbing, text, annotation,…To do this i use Curic Single-Line, and paint the group.
With 5D+ Plus , this seems not possible ? Using a Style with edges set to material seems to mess things up. Because how the Annotation and Dimension tools behave, Curic Text show only the faces and hides the edges.
Also with the dimensions tool, there is no way to color dimension line, only give text a color.
Is there another way how i can add color tot edges using 5D+Plus?
Attached is an image from what i try to achieve.
Thanks!
@Cyentruk I work with wood framed buidlings and need to dimension sometimes to the wood frame and sometimes to the finished wall, so I need to see clearly what I am snapping my dimension line to. In paper, even on the high quality viewport, its too blurry for me to use the dimensions.
In model space, because the dimension lines and text are actual modeled objects, they sit behind the cut line. Is there a solve for how to see the whole arrow and extension at the wall? And the “Move text outside when too narrow” does not seem to work, I have to manually move the text, but it would be very cool if it could have a curved leader that goes back to the dimension string.
Hello and sorry for the late reply.
You can set Curic Text edges and faces ON/OFF here as default
You can continue to use you own method, but you can also set PDF Line Styles when using Paper.
People used Curic Section/Skalp to create section hatches. They are faces are painted materials or assigned tags, so they can setback and the section fills were turned off. That can solve the issue.
Thanks for the suggestion, this will be supported in the next version.
Hello Cyentruk
I’m new to 5D+ Plus, but thanks to its intuitive interface and your tutorial videos, I think I’ve learned a lot about the basics. However, I don’t understand how to manage hybrid components and their 2D and 3D representations. When in Paper, I’m still viewing the top view (3D representation) of the component instead of the 2D representation, which is more suitable for drawings and DWG export.
Since this thread is very long, I need your assistance to find the right post and learn on my own, or, if you have time, guide me on how to do this in my models.
Also, I need assistance with loading classification files. I’ve downloaded the samples but still don’t know how to use them.
Thanks in advance
GaMo
Hello @arq.gamo, to create a hybrid (2D/3D) component, you can use tags because their visibility can be saved per scene.
  1. Create two tags named #2d_graphic and #3d_object.
  2. Inside the component, create two child groups.
    • Assign the group containing the 2D elements to #2d_graphic.
    • Assign the group containing the 3D elements to #3d_object.
Then, in each scene, turn #2d_graphic and #3d_object on or off depending on what you want to show, and update the scene to save their visibility settings.
Thank you, @Cyentruk
The solution was really easy. For the components I’ll create, I’ll do as you say and create new tags to control visibility. For the FlexTools components, I’ll turn off the 3d elements’s tag in the plan view and update the view.
I tried both, and it is working as expected.
Kind regards,
GaMo
That’s a great tip. You can also look how are the 5d window component formed.
I go a step further for trees in my workflow. I place enscape rendered asset components and assign them a render tag only visible in a specific 3d view used for rendering. Then in same component I add a plan view for the Tree in the 2d layer and another in 3d for the sections and elevation views.
This work also for furniture where I only want simplified line work version of chairs and tables (similar to autocad) in plan view but I use complex objects in sections elevations and render view
That’s true. It is simple but works.
Help please.
  1. I can not find a way to drag a scene onto a sheet. In the 5D+Plus 3.2.0n version, Sheet tab, there is a Drag Scenes here section. How does one drag a scene here? In the Scenes tab there is the “Drag onto the active” sheet icon but nothing happens when this is selected. Dragging from the Scenes tab to the Sheets tab is not possible. I am not able to get the Scene to the active sheet.
  2. On the Grids tab, I have created the grid for the project with the Floor-Dim scene. The grid is good. Selected the Check mark and Save. What is the process of showing the grid in the scenes or on the sheets. I have watched YouTube and read instructions but do not know how to complete this process.
    I am reaching out because you are updating 5D+ Plus quickly so the dialogs are changing and the help information does not match the current version. Please help because I am in the middle of a small house project and am stuck. Thank you.
The help image above on the left show the sheet next to the scene list where one can drag the scene onto the sheet. The 5D+ Plus dialog on the right is current version and the sheet section is not available. In the current version, Scenes and Sheets are separate, and I do not know how to get the scenes on the sheets.
The version you are using is v3.2.0n. It is the developing version for the official version 3.2.0. You can upgrade from the v3.0.0 because of a technical issue.
The green arrow to drag a scene into a sheet in the list
The red arrow to drag scene from icon directly to the paper space.
