5D+ Plus - Flexible Documentation For Architects
This question should be asked in this topic may be better.
5D+ Auto Tag - Manage and import/export tags with textures - Extensions - SketchUp Community
Anyway, 5D+ Auto Tag does not support import tag folders, but you can use this function, if you have your own tag folders
Here is how:
  1. Setup
  2. Apply in any files
5D+ PLUS VERSION 2.6.0 IS OFFICIAL RELEASED!
Version 2.6.0 is finally here, bringing one of the most significant updates in 5D+ history.
The highlight is our completely redesigned DXF/DWG export engine—the best exporter we’ve ever built—delivering faster performance, cleaner CAD output, and higher compatibility than ever before.
This release also includes a wide range of improvements, new features, and bug fixes across the entire extension.
Release notes: 5D+ PLUS - RELEASE NOTES
Check for Updates in 5D+ Plus and upgrade today!
If you want to try for free 30-days:
Click here: 5D+ TRIAL
Now you can export standard views of selected object included sections and texture directly to DWG with 5D+ Plus upcoming version 2.7.0
2D Projection for Multiple Sections, a new feature in upcoming version 2.7.0
The wait is over! Version 2.7.0 brings new tools and improvements to make architectural documentation inside SketchUp even more flexible and efficient.
Radial Grid
Create radial grid systems with both circular and radial axes.
Coordinates
Draw site boundaries with elevation data, create contour lines, and transform model coordinates into real-world coordinates.
Create 2D Projection
Project 3D objects directly into 2D geometry on the working plane. Easily represent roof overhangs, elements above the cut plane, ceiling finishes, fixtures, and equipment — especially useful for Reflected Ceiling Plans (RCPs).
Generate 2D Drawing
Generate multiple orthographic, section, and isometric views with dimensions in a single action. Export directly to DXF, DWG, or SketchUp, or place the entire drawing set directly into the current model.
Check out the full changelog: RELEASE NOTES
5D+ Plus version 2.7.5 has been released to fix an issue that prevented the extension from opening in SketchUp 2021, as reported by @BHDesign, along with several other fixes.
Hey @Cyentruk
I have a question on a small problem we have.
The dimension we add using this plugin they look amazing in sketchup but as soon as we export them to layout or as a PDF for us to print the dimension line goes through the number even though I have the background enabled and it looks fine in sketchup.
Is there a solution to this other than moving the numbers in a different position?
Thanks in advance!
Huhm, this is not happened from my side. What version of 5D+ Plus you are using? Did the issue happen will all the views?
Here is a sneak peek of 5D+ Paper, a total brand new feature in coming version 3.0.0
Yes it happens with all views. I’m using V2.7.7
If I was able to put a small offset on the numbers and background, I think it would fix the problem.
I think it’s because they are on the same exact plane and they overlap, As soon as I move the camera in sketchup the line appears
Thanks!
Very cool! :smiley:
Actually I put a small offset from the text to the line. The bad visual when orbiting 3D is known, but when it comes from ortho view, the offset still works fine from my side (as the image I sent above). Just still not know why it happens to you. Can you send me your file? I’ll take a look.
I have a save of one of your models I can send where the same problem happens.
Where can I send you the file
Thanks!
You can send me the file or the link of the file via message of this forum.
It’s always interesting for me to see how other architects understand and use 5D+ in their own workflow.
Joshua de Bruin from Studio JDB has just shared a detailed video exploring 5D+ from an architect’s perspective — including how it fits alongside SketchUp, LayOut, AutoCAD and Revit workflows.
Thank you @joshua_studiojdb for taking the time to explore 5D+ and share your experience with the SketchUp community. I really appreciate it!
Hi everyone, total noob here, first day of learning what looks like a very powerful plugin. I cannot find any documentation on the dimension tool. I can make a string of dimensions snapped to points of geometry, but they disappear as soon as I make them.
They’re probably above your section planes. Sometimes this happens to me too.
Hmm, I think something else might be going on. I made a brand new file and made a simple shape and a plan and elevation scene and tried to dimension the plan. here is a screen capture. any other theories?
Try watching the Tags tray and see if you have turned on some plugin that makes new tags automatically turned off.
Maybe auto invisible layers plugin?
Auto-Invisible Layer | SketchUp Extension Warehouse
It also seems that sketchup also performs this action automatically nowadays. I wasn’t aware.
