This extension is amazing.
@Cyentruk how are you getting views into LayOut? Is there no faster way than copying viewports and selecting scenes one by one?
New toy: “Classify Elements”
This is an upgrade version from an existing tool named “Nested Group” and will be available in the upcoming version. ![]()
This new toy uses Overlay, a feature only available from SketchUp 2023. It’s always show in your screen and helps you classify elements to your tags system but seems not care too much about tag. ![]()
Power Nerd! ![]()
That seems like a great classification method.
Will that classification system:
I will be a tester as well, unless the window for this has closed. Still getting a hang of all the features…
Regards
I’ll test…
It would be great if it was possible to leverage the “create 2D drawing” function, in order to create a set of back view dashed edges, for plans, from the corresponding ceiling views.
5D+ would:
This way we could generate something like the standard dashed lines that are dividing rooms or defining the porch ceiling here:
@Cyentruk, I already found the older version. But the Display Label is still glitching and the Dim. Endpoints disappeared
Why are you using testing versions if you cannot afford something to break or not work?
It’s the same as upgrading to a new SketchUp version in the middle of a time sensitive project…
I have the official version, but I couldn’t remember where I could find it. Moreover, I am connected with the author through FB, Google Chat, here; he answers quite quickly. And last but not least, I installed the testing versions to contribute to improving the extension. I think I am doing a good thing, even if you consider vice versa.
I’m not saying it’s a bad thing to help with testing. I was just wondering why someone would use testing/beta versions when on a timelimit. Doesn’t seem sensible to me.
When I am working to a deadline, I’m not going to try out a new tecnique with a new tool I have never used before.
I think the discussion has gone off-topic. But thank you so much for your concern
You’re welcome.
Hello, you can download official version (and a version before) from your account at Lemon Squeezy. How to access your account? There 3 ways:
I already found it, thanks
From the new version, as @JQL had requested, I have removed Endpoints option from Auto Grid and Auto Level. Now the dimension when creating will follow dimension 's settings in Model Info.
