5D+ Auto Info - New way to extract information from model
You need to remove Level 2 completely. If not, it’s still select all objetcs from Level 2 without conditions.
THANKS !!!
Hi there, me again.
Is it possible to modify the text of the description, but not within the Auto Info Window, directly on Sketchup ?
Hi.
5D+ AUTO INFO IS OFFICIALLY UPDATED!
Version: 1.4.1 - Release date: 2025.03.31
  • Custom Columns Support - Now you can add custom columns to display additional attributes from Dynamic Components - making your reports even more flexible and informative.
  • Enhanced Table Experience - I’ve improved the table interaction to make your workflow smoother:
    • Easily resize column widths with a more intuitive and fluid experience.
    • Edit headers and cell values directly in the table, faster and easier than ever.
  • Draw Table into SketchUp Model - A brand-new feature! You can now draw the table along with images directly into your SketchUp model - perfect for presenting data visually inside your project.
  • Export Table to Excel (with Images & Styles) - Exporting to Excel just got better:
    • Supports image export without the need for macro files.
    • The exported table now comes with improved and beautiful styling.
  • Dark Mode Support - You can now easily switch between Light and Dark themes for a more comfortable viewing experience.
  • Multi-language Translation - All UI phases are now fully translated into 20 supported languages, making it easier for users around the world.
Important notice: After update this version, you may need to reset presets to default settings.
In the new version, the UI is improved in expanding, collapsing the table, resizing columns and editing cells.
Em yêu sếp Nghỉa
Draw the table into SketchUp model. This will help you create a scene for the table and use it in LayOut without manually inserting images. Tips: choose top view with parrallel projection, and change all texts to Height = 13mm for best result.
Draw Table A
This will be done in the next release.
The column widths are remembered from the last changed (latest version).
Done!
Done!
Thanks to all of you. Let update to the latest version and leave me your suggestions.
Hi there Musarrat Shah from Pakistan. Really happy to see such extension. Nice work. I tried the trial version. Any possibility to automate the dimensions. Also make. project based step by step tutorial like start the project ( Design ) to finish drawings ( PDF ) in English language. Current videos are helpful but confused when we look video for specific task or there is not much of our interest. Thank you.
Hi, thank you for using my extension. But it seems you are talking about another extension name “5D+ Plus”? Because this topic is for the extension name “5D+ Auto Info”.
@Cyentruk I have downloaded the latest version of 5d_auto_measure but when I click the toolbar it does not work, is there something that could be affecting this?
Hi,
Maybe the plugins conflict? Could you open the Ruby Console to see any reports from there when click the icon on the toolbar?
Anyway, this is the topic for 5D+ Auto Info and there is a topic for 5D+ Auto Measure here: 5D+ Auto Measure - Advanced measurement tool
Version 1.4.6
(Release date 2025.05.31)
  • Add ability to choose tag and material from the table
  • Improve performance when editing and replacing information
  • Fix the issue calculates wrong projected area for scaled object
  • Support full translation
  • Fix bugs
Is something new here? It seems to me that these options already existed.
I’m missing about column (X) x (Y), but editable tag and material is new (actually they are brought back and more stability after removed from previous versions).
It means you can doule click to choose tags and materials from a list.
Cool feature! Unfortunately, the search bar doesn’t work properly; it only updates if I select the material from the list
Update: Another possible bug. After selecting a different material and then reselecting the component, the new material is not saved.
Update2: Don’t you think it would be better for “Show Total Row” to be placed here?
Thanks. This is surely a bug. I’ll fix it.
I have released 1.4.5 that fix the bug.
Version 1.4.6 is now available with this recommend. :grin:
P/S: Control displaying for many languages is one of the hardest part. I must based on a language has longest string to control where to decide to hide buttons when user resizing windows. That’s the reason I don’t want to put the total row switch button in the footer at the begining.
auto_info
Hi @Cyentruk - Question - can I use the plugin to find the global XYZ coordinates of every object selected? I haven’t found these columns but maybe I am missing something.
Hey man, currently the extension is not support to get the global XYZ coordinates cause I thought there is not many user need them I can add it into the next update.
I just realized that this is much more tricky than I thought. If you’d include that you would likely go the same way that the native report generator would go, looking for the origin of each object and calculating the distance from the model origin. However, the origin of component can be basically anywhere. What I would need would be the centerpoint of the bounding-box of the component - not sure if this is a readily available information. If not this would likely be too big a hazzle.
