3dconnexion not showing up in extension manager
Reinstalled SU2025 application successfully after it became corrupt. 3DConnexion extension did not show up in extension manager. Reinstalled 3DConnexion driver in windows 10, but still the extension is not showing up in extension manager of SU2025.
From the 3D connexion Support page.
Tried this and it is either outdated (3 years old), or it doesn’t work at all. I’m working with 3DConnexion support. They have yet to come up with a useful solution.
I have the old wired Space Navigator device. When SketchUp 2025 was released I downloaded the 3DxWare64 installer, version 10-9-3_b671, installed and it works as it should. The extension SketchUp needs to work was installed “automatically”.
There still might be something wrong with your SketchUp installation. You could try right-clicking on the installer, selecting “Run as Administrator” from the popup menu, and selecting Repair when the installer dialog appears.
I’ve seen a few people have an issue because the driver has installed twice in different folders.
You could try searching for any files and folders called 3DxSketchup and see if there is more than one folder and one .rb with this name related to 2025. There will be lots of other file extensions in the list, but it is the Plane Folder and the one .rb with 2025 in the file name path that is relevant.
If there is more than one of each, the ‘correct’ ones would be in
C:\ProgramData\SketchUp\SketchUp 2025\SketchUp\Plugins
Can you shere the solution please?
