3D Connexion Spacemouse Crashing SketchUp 2026 upon opening
I was battling this about a month ago when I finally decided to update to 2026. I was on 2024 before and the 3D Connexion mouse has always worked fine. I 100% know its the Space Mouse extension because when I run 3DxWare64_v10-9-9_b721 as Admin, modify and uncheck the box for Sketchup, I can open 2026 just fine. I REALLY want to be able to continue using this mouse. I was having the same issue with 2025 but I found a loophole by adding BAK to one of the Sketchup file names, I think in Program Files. It reset everything and I had to rebuild 2025 from scratch (tray / toolbars / etc), but it worked. Now I can’t remember exactly how I did that. Feeling dumb. Please help!
After posting this I immediately discovered the was a new driver update for 3D Connexion. 3DxWare64_v10-9-10_b725
Same issue! SketchUp 2026 crashes when I try to open it.
Have you restarted your PC after the install of the new drivers?
RaydonConcepts
1m
Definitely
You are likely speaking of the "PrivatePreferences.json" file.
On Windows, it is located in: %LocalAppData%/SketchUp/SketchUp 2026/SketchUp
The renaming must be done whilst SketchUp is closed.
