3D connexion navigator will not function with v2019 I had the identical issue when upgrading to 2018.
Below is the instruction to resolve the problem that worked for v2018 but doesn’t for v2019. I need the navigator for an animation production for my final year fine art degree show. Time is running out…
I have contacted 3D connexion I’m waiting for a response, in the meantime any ideas would be appreciated.
Thanks
Phil
We assume that the driver does not start correctly.
The reason is the file 3DxServiceState.xml.
Please try the following:
- Navigate to the folder “C: \ Users \ Username \ AppData \ Local \ 3Dconnexion \ 3DxWare”.
- delete the file “3DxServiceState.xml”.
Start the driver. (Start the driver. (Start Start -3Dconnexion driver).
This process recreates the file and the driver works.
Best regards,
3Dconnexion technical support
