I feel like there is a regression in 2027 regarding duplicate entities when exporting DXF files. It probably happens with other formats, but I encounter it in my workflow with DXF.
I export flat geometry for CNC routing and have done so with SU Pro for years, and it has been excellent at culling duplicate entities when exporting from an orthographic view in wireframe mode. Given a cube in plan view, for example, I always get four clean lines and not eight in 2026 and prior. Now with 2027, I get all eight lines and then have to cull duplicates manually or with a script in QCAD. Not good.
I have a script that sets top view, wireframe mode and turns off profiles, and my export options are absolutely bare with 1:1 scale set and zero options enabled. I’m happy to provide an example file, but it’s trivial to reproduce in wireframe top-view with edge profiles disabled.
That’s not a good situation and hopefully it will be fixed soon. In the meantime, an option would be to export the DXF from LayOut after vector rendering the viewport(s).
The other option would be to go back to using SketchUp 2026 for export.
I am having the exact same problem. I export my files in .dxf and my CNC operator opens that file in V-Carve. He has shown me where ever line is duplicated in files from SU27, but not in SU26.
For the time-being, you could use QCAD (which is an awesome CAD program for editing DXF/DWG) which has a Modify > Detection > Detect Duplicates command that selects exact duplicate entities, then delete them.
There is also a Misc > Modify > Flatten Drawing to 2D command which ensures the drawing is flat, but I don’t remember if that menu is in the default install… I have written a few plugins for it and I think that menu comes from a set of scripts that have to be installed. If you do like me and use a plan view, you should be 2D already from SU Pro.
For now, go to the preferences and switch the Vector Rendering Engine to the classic renderer and it will revert to the old behavior. The SU team is now looking into the changed behavior in the new engine. To clarify, this is the Vector Rendering Engine and not the Graphics Engine setting.
