2026 Issues
Right-click on a .skp file and choose properties
Then do the same for the .layout file
Mine only shows one “Sketchup Application” option under default app, and nothing under suggested apps or more options.
BTW: Windows 11
Maybe if I choose the app manually? If so, what file am I suppose to choose?
Yes SketchUp.exe is the correct file to choose, in the version folder you want.
Thanks! Appreciate the help!
Same problem, maybe I’ll back to 2024 version till the next fix update of 2026.
I may have found a new one and I think it’s a big one. tldr; gridlines show up properly in LayOut 2025 but not in LayOut 2026.
With the general rule of only groups and components placed on tags and geometry on ‘untaggged’ my grid lines (which have multiple nested parts, 2d linework [for plans] and 3d planes [for elevations], all on different tags for control) LayOut 2026 appears to not respect the ‘default’ setting for the tag they are set on and the linework needs to be put on the tag with the dash.. So my 2d gridline geometry(the lines) are on ‘untagged’, but multiple levels up they are set to a tag that has a dashed line type. LayOut 2026 shows them a solid line and will only be dashed line until I place the lines on the tag with the dash line type. Layout 2025 shows them as the dash they intended to be.
Upon further testing, and making of attached files, in raster mode, they show up properly, in hybrid or vector they do not.
Linetype problem.skp (559.9 KB)
Linetype problem.layout (532.0 KB)
After downloading 2026 my .skp files in finder does not show thumbnails - cant find any SUModel.qlgenerator?
Another issue with Layout. Its minor but annoying. The SketchUp Model Tray/Tags can no longer be resized. If the number of tags requires a scroll down then when you check or uncheck Tag visibility it jumps (scrolls) back to the top.
Strange issue: yesterday used SU2026 without any problems. Closed normally. Today when starting SU2026 it ‘acts‘ as if its the first time I use it so no drawing history and asks to migrate all SU 2025 plugins…. Also UI is default so have to do the setup again. What could cause this?
Edit: Layout 2026 acts normally.
Edit2: in the SU2026 directory, all the already migrated plugins are present
Did you also see a dialog asking if you agree to the Trimble conditions? If you did, that would suggest the preferences file had been deleted.
You could go into this folder (paste this path into File Explorer), and see if PrivatePreferences.json has any permissions issue:
%LocalAppData%\SketchUp\SketchUp 2026\SketchUp\
One thing you could do, while SketchUp is closed, is to duplicate that file, delete the original, and then rename the copy as PrivatePreferences.json. Then you can be sure that you have correct permissions for the file.
Hi Colin, thanks for the reply.
I didn’t get the dialog about the conditions. Can’t try the rest. Had to use SU26 today so did the migration etc to get back to working. Will keep this in mind in case it happens again.
Doubleclick mousebutton doesn’t work. I have a Logitech G502 Hero mouse,
assigned a doubleclick and a triple click and heavily using the doubleclick.
In SKP and LO Version 25 it works fine, in Version 26 the doubleclick doesn’t work at all,
triple yes…
Just for clarity, you are talking about a programmable extra button and not your left mouse button?
Yes, a bit weird I think. left an right mousebutton work as normal, programmed doubleclick works like single click, programmed triple works as normal…
Could be a Logitech thing..
But then, you’re saying it works in 2025..
I wonder if the Logitech software needs to be set up for each version of SketchUp?
if you add software specific stuff, it does. because it’s not the same software.
resolved without knowing why it didn’t work in SKP2026…
the triple click already was a programmed makro, made with the software of the logitech mouse,
and so I did now with the doubleclick…
I think I saw this happening in earlier releases also. When creating a shape with the line tool in Layout then going back to edit the shape the points can be moved as they should but the ability to add or subtract points using CTL, Shift doesnt work. Using ALT to add to curves seems to work.
right click to export in the pages tray, well i never knew….. i learned something new today :grinning_face: this fixes my problem when i export from range and choose page 4 of 4 pages it comes out backwards
anybody have an idea why i cant open straight to blue beam
