2024 Window Tray
Issue SU 2024:
The Window Tray (SU 2024 Windows running a Dell XPS with Nvidia GPU) shows wrong pointer graphic (it shows a graphic normally used it indicate “window size” 2 bars with arrows) rather than the select arrow graphic.
In addition, the “Tags” window does not allow the user to add sub folders under the current Tag.
Sorry but a subscription based application (several hundred dollars per year) should not have such issues with upgrades. If it is just a personal problem (user error), I apologize. Otherwise, I expect better from a premier software vendor.
This has been reported already. Several threads on it here in the forum. Hopefully it’ll be fixed in the first maintenance release.
Please update your forum profile. It says you’re still using SketchUp 2022.
